[mapguide][MG272][Modified] AJAX: Polyline and point selection does not work
Alain Lebatard alain.lebatard at autodesk.com
Tue May 2 13:17:42 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG272
Type:
Defect
Artifact ID:
MG272 (AJAX: Polyline and point selection does not work)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Build set to new value:
173.2
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution Description set to new value:
The selection worked fine. However the rectangle used in the QUERYMAPFEATURES request for selection was slightly narrower than the one used to request tooltip info, making it more difficult to select point and line features.
This submission makes that a rectangle of the same size is used in both cases.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
