[mapguide][MG273][New] Most error log entries are not being written to the error lo...
Bruce Dechant bruce.dechant at autodesk.com
Wed May 3 11:25:48 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG273
Type
 Defect
Artifact ID
 MG273 (Most error log entries are not being written to the error log.)
Reported by
 Bruce Dechant
 brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Priority set to new value
  P2
- Summary set to new value
- Steps to Reproduce set to new value
  Try and delete a resource that doesn't exist and you will get the proper exception back to the client, but no entry written to the error log.
- Component set to new value
  Server
- Description set to new value
  The server operation processing cleanup work done with artifact MG252 inadvertently removed the ability to log most server errors. This needs to be corrected.
- Subcomponent set to new value
  Core
- Defect Severity set to new value
  High
- Artifact created
- Artifact Status set to new value
  New
- Version set to new value
  1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
