[mapguide][MG270][Modified] Nothing draws if point symbol is missing from the library
Traian Stanev
traian.stanev at autodesk.com
Wed May 3 11:43:39 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG270
Type:
Defect
Artifact ID:
MG270 (Nothing draws if point symbol is missing from the library)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG270: Nothing draws if point symbol is missing from the library
Added check for aspect ratio changes from one feature to the next.
Modified
File: trunk/MgDev/Common/Stylization/GDRenderer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/GDRenderer.cpp?view=diff&rev=604&p1=trunk/MgDev/Common/Stylization/GDRenderer.cpp&r1=603&p2=trunk/MgDev/Common/Stylization/GDRenderer.cpp&r2=604
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
