[mapguide][MG252][Modified] Server hung/crashed after running load tests
Walt Welton-Lair
walt.welton-lair at autodesk.com
Wed May 3 12:22:24 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG252
Type:
Defect
Artifact ID:
MG252 (Server hung/crashed after running load tests)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG252
Modified
File: trunk/MgDev/Common/Service/Services/Command.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Services/Command.cpp?view=diff&rev=606&p1=trunk/MgDev/Common/Service/Services/Command.cpp&r1=605&p2=trunk/MgDev/Common/Service/Services/Command.cpp&r2=606
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
