[mapguide][MG276][New] Selected features not highlighted when feature is joined to ...
Ronnie Louie
ronnie.louie at autodesk.com
Wed May 3 17:26:39 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG276
Type
Defect
Artifact ID
MG276 (Selected features not highlighted when feature is joined to ODBC source)
Reported by
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Summary set to new value
- Description set to new value
Selected features should be highlighted in the viewers. However, highlighting does not occur when the selected feature is joined with ODBC secondary source when using the AJAX viewer. The properties pane and the status bar indicate that the feature is selected, but the AJAX viewer does not show any highlighting.
- Subcomponent set to new value
Feature Service
- Version set to new value
1.0.0
- Target milestone set to new value
1.0.1
- Steps to Reproduce set to new value
1. Using a SDF based features source, join this to an Access database via ODBC.
2. Create a layer from this feature source with the extension feature class.
3. Insert the layer into a Map, and create a WebLayout for the Map.
4. View the map using AJAX viewer, and attempt to select features.
5. Notice status bar in properties pane indicates that features are selected, but do not appear a highlighted.
- Priority set to new value
P2
- Defect Severity set to new value
High
- Artifact Status set to new value
New
- Artifact created
- Component set to new value
Server
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
