[mapguide][MG276][Modified] Selected features not highlighted when feature is joined to ...
Ronnie Louie ronnie.louie at autodesk.com
Wed May 3 17:37:47 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG276
Type:
Defect
Artifact ID:
MG276 (Selected features not highlighted when feature is joined to ODBC source)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
The MgServerDescribeSchema::GetIdentityProperties() method was returning the id properties for the secondary feature source, when in fact it should be returning the ones for the primary feature source.
-- Testing Notes set to new value:
Server unit tests debug: 380/380 tests OK
Server unit tests release: 380/380 tests OK
-- Build set to new value:
173.3
-- Artifact Status changed:
Old value:
New
New value:
Assigned
-- External ID set to new value:
765342
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
