[mapguide][MG277][New] Fix Feature Service unit test broken as a result of update F...
Ronnie Louie ronnie.louie at autodesk.com
Thu May 4 12:07:07 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG277
Type
 Defect
Artifact ID
 MG277 (Fix Feature Service unit test broken as a result of update FDO update)
Reported by
 Ronnie Louie
 ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Summary set to new value
- Version set to new value
  1.0.0
- Priority set to new value
  P2
- Defect Severity set to new value
  High
- Artifact Status set to new value
  New
- Component set to new value
  Server
- Artifact created
- Build set to new value
  173.4
- Description set to new value
  The Feature Service unit test TestFeatureService::TestCase_GetCapabilities() is failing due to update to FDO which does not require version in the provider name.
- Related Artifacts set to new value
  Mg275
- Steps to Reproduce set to new value
  Run Feature Service unit tests.  Notice failure in TestFeatureService::TestCase_GetCapabilities().
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
