[mapguide][MG277][Modified] Fix Feature Service unit test broken as a result of update F...
Ronnie Louie ronnie.louie at autodesk.com
Thu May 4 12:13:53 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG277
Type:
Defect
Artifact ID:
MG277 (Fix Feature Service unit test broken as a result of update FDO update)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- Target milestone set to new value:
1.0.1
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution Description set to new value:
The TestFeatureService::TestCase_GetCapabilities() passed the provider name to MgFeatureService::GetCapabilities() which in turn passed to the name directly to FDO to create a connection.  This was failing because the name should not contain version.  Resolved by using method MgFdoConnectionManager::UpdateProviderName() submitted in MG275 to remove the version from the provider name before it is sent to FDO to create the connection.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
