[mapguide][MG278][Modified] Fix broken Web tier unit tests due to FDO update
Ronnie Louie ronnie.louie at autodesk.com
Thu May 4 17:59:42 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG278
Type:
Defect
Artifact ID:
MG278 (Fix broken Web tier unit tests due to FDO update)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Updated test data baseline for unit tests.
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
