[mapguide][MG281][New] Service operations not authenticated before executing
    Ronnie Louie
    ronnie.louie at autodesk.com
    Fri May  5 17:25:43 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG281
Type
 Defect
Artifact ID
 MG281 (Service operations not authenticated before executing)
Reported by
 Ronnie Louie
 ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Resolution Description set to new value
  Authentication needs to be added to the remaining service operations.
- Version set to new value
  1.0.0
- Artifact Status set to new value
  New
- External ID set to new value
  785677
- Component set to new value
  Server
- Defect Severity set to new value
  Critical
- Description set to new value
  All service operations should be authenticated before they are executed.  An analysis of the code indicated that only Resource service, ServerAdmin service and Site service operations where authenticated.  The rest of the service operations in FeatureService, MappingService, DrawingService, TileService and Rendering Service did not perform authentications before executing.
- Priority set to new value
  P2
- Artifact created
- Steps to Reproduce set to new value
  Call an API from one of the above mentioned services (ie FeatureService::SelectFeatures).  Step thru code and notice that operations executes without prior authentication.
- Target milestone set to new value
  1.0.1
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
