[mapguide][MG282][New] Fix globalization issue with print view page in AJAX Viewer
Walt Welton-Lair
walt.welton-lair at autodesk.com
Tue May 9 01:09:39 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG282
Type
Defect
Artifact ID
MG282 (Fix globalization issue with print view page in AJAX Viewer)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Steps to Reproduce set to new value
1. Create a layer with JPN strings as a legend name and publish it to view it from viewer.
2. From viewer, click on print button.
3. Verify including legend check box is on.
4. Click on Create Page button.
Problem: Print view page with broken JPN strings as a legend name.
- Platform set to new value
All
- Component set to new value
Server
- Subcomponent set to new value
Mapping Service
- Version set to new value
1.0.0
- Target milestone set to new value
1.0.1
- Defect Severity set to new value
High
- Summary set to new value
- Priority set to new value
P2
- Artifact Status set to new value
New
- Artifact created
- Description set to new value
The legend code used by Print View Page (with the AJAX Viewer) is hardcoded to use the Arial font. If any layer legend names contain characters which are not in the font (e.g. Japanese characters) then these will not draw correctly.
- Operating system set to new value
All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
