[mapguide][MG282][Modified] Fix globalization issue with print view page in AJAX Viewer
Walt Welton-Lair
walt.welton-lair at autodesk.com
Tue May 9 01:13:48 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG282
Type:
Defect
Artifact ID:
MG282 (Fix globalization issue with print view page in AJAX Viewer)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Assigned
-- Developer Notes set to new value:
The fix for this will be to add a server configuration setting which specifies which font to use for the legend preview. This is not much different than labels, in which the user also has to specify which font to use. The only difference is that this is a global setting and not a per-layer setting.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
