[mapguide][MG282][Modified] Fix globalization issue with print view page in AJAX Viewer
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue May 9 01:34:42 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG282
Type:
Defect
Artifact ID:
MG282 (Fix globalization issue with print view page in AJAX Viewer)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Testing Notes set to new value:
Tested by copying the MS Mincho font to the server bin directory, and ran the print view page command.  The legend correctly now correctly displayed the Japanese characters.
Also ran the server unit tests - all tests passed under Linux (FC 4).
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
