[mapguide][MG281][Modified] Service operations not authenticated before executing
Ronnie Louie
ronnie.louie at autodesk.com
Tue May 9 13:53:13 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG281
Type:
Defect
Artifact ID:
MG281 (Service operations not authenticated before executing)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Old value:
Authentication needs to be added to the remaining service operations.
New value:
- Updated service operations to call pure virtual method Validate() that will perform necessary validation checks based on the service type before the operation executes. This is done because, not all service operations require user authentication, and not all service operations require licensing. By making a call to a pure virtual method, the necessary checks can tailored specifically for each service.
-- Build set to new value:
174.3
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
