[mapguide][MG285][New] Update GetSchemaMapping API to return additional information...
Bruce Dechant
bruce.dechant at autodesk.com
Thu May 11 11:02:41 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG285
Type
Defect
Artifact ID
MG285 (Update GetSchemaMapping API to return additional information needed by FDO)
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Defect Severity set to new value
High
- Artifact Status set to new value
New
- Operating system set to new value
All
- Platform set to new value
All
- Target milestone set to new value
1.0.1
- Summary set to new value
- Steps to Reproduce set to new value
FDO fails to process the existing configuration document built using this API.
- Priority set to new value
P2
- Component set to new value
Server
- Subcomponent set to new value
Feature Service
- Artifact created
- Version set to new value
1.0.0
- Description set to new value
The current implementation of the GetSchemaMapping API returns only the schema mapping information as an XML document.
FDO actually requires the following:
1) Spatial context
2) Schema
3) Schema Mapping
This API needs to be updated to return the required additional information needed by FDO in order to process the schema mapping information.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
