[mapguide][MG288][New] Server needs some optimization to reduce the number of repos...
Steve Dang
steve.dang at autodesk.com
Sat May 13 23:22:12 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG288
Type
Defect
Artifact ID
MG288 (Server needs some optimization to reduce the number of repository deadlocks)
Reported by
Steve Dang
stevedang (steve.dang at autodesk.com)
New artifact details:
- Priority set to new value
P2
- Summary set to new value
- Component set to new value
Server
- Subcomponent set to new value
Resource Service
- Description set to new value
Server needs some optimization to reduce the number of repository deadlocks.
1. Retry the operation a few times before failing instead of failing immediately when the database is locked.
2. Avoid using locks for read-only operations when possible.
- Operating system set to new value
All
- Platform set to new value
All
- Artifact Status set to new value
New
- Version set to new value
1.0.0
- Artifact created
- Target milestone set to new value
1.0.1
- Steps to Reproduce set to new value
1. Run the load tests.
2. Notice the results shown quite a number of deadlocks.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
