[mapguide][MG288][Modified] Server needs some optimization to reduce the number of repos...
    Steve Dang
    steve.dang at autodesk.com
    Sat May 13 23:42:49 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG288
Type:
Defect
Artifact ID:
MG288 (Server needs some optimization to reduce the number of repository deadlocks)
Modified by:
Steve Dang
stevedang (steve.dang at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
Modified
File: trunk/MgDev/Common/Service/Data/ByteReader.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Data/ByteReader.cpp?view=diff&rev=648&p1=trunk/MgDev/Common/Service/Data/ByteReader.cpp&r1=647&p2=trunk/MgDev/Common/Service/Data/ByteReader.cpp&r2=648
File: trunk/MgDev/Common/Service/Data/ByteReader.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Data/ByteReader.h?view=diff&rev=648&p1=trunk/MgDev/Common/Service/Data/ByteReader.h&r1=647&p2=trunk/MgDev/Common/Service/Data/ByteReader.h&r2=648
File: trunk/MgDev/Common/Service/Data/ByteSourceFileImpl.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Data/ByteSourceFileImpl.cpp?view=diff&rev=648&p1=trunk/MgDev/Common/Service/Data/ByteSourceFileImpl.cpp&r1=647&p2=trunk/MgDev/Common/Service/Data/ByteSourceFileImpl.cpp&r2=648
File: trunk/MgDev/Common/Service/Data/ByteSourceFileImpl.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Data/ByteSourceFileImpl.h?view=diff&rev=648&p1=trunk/MgDev/Common/Service/Data/ByteSourceFileImpl.h&r1=647&p2=trunk/MgDev/Common/Service/Data/ByteSourceFileImpl.h&r2=648
File: trunk/MgDev/Common/Service/Data/ByteSourceImpl.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Data/ByteSourceImpl.h?view=diff&rev=648&p1=trunk/MgDev/Common/Service/Data/ByteSourceImpl.h&r1=647&p2=trunk/MgDev/Common/Service/Data/ByteSourceImpl.h&r2=648
File: trunk/MgDev/Common/Service/Data/ByteSourceMemoryImpl.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Data/ByteSourceMemoryImpl.cpp?view=diff&rev=648&p1=trunk/MgDev/Common/Service/Data/ByteSourceMemoryImpl.cpp&r1=647&p2=trunk/MgDev/Common/Service/Data/ByteSourceMemoryImpl.cpp&r2=648
File: trunk/MgDev/Common/Service/Data/ByteSourceMemoryImpl.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Data/ByteSourceMemoryImpl.h?view=diff&rev=648&p1=trunk/MgDev/Common/Service/Data/ByteSourceMemoryImpl.h&r1=647&p2=trunk/MgDev/Common/Service/Data/ByteSourceMemoryImpl.h&r2=648
File: trunk/MgDev/Common/Service/Data/ByteSourceSocketStreamImpl.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Data/ByteSourceSocketStreamImpl.cpp?view=diff&rev=648&p1=trunk/MgDev/Common/Service/Data/ByteSourceSocketStreamImpl.cpp&r1=647&p2=trunk/MgDev/Common/Service/Data/ByteSourceSocketStreamImpl.cpp&r2=648
File: trunk/MgDev/Common/Service/Data/ByteSourceSocketStreamImpl.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Data/ByteSourceSocketStreamImpl.h?view=diff&rev=648&p1=trunk/MgDev/Common/Service/Data/ByteSourceSocketStreamImpl.h&r1=647&p2=trunk/MgDev/Common/Service/Data/ByteSourceSocketStreamImpl.h&r2=648
File: trunk/MgDev/Common/Service/Data/ByteSourceStreamImpl.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Data/ByteSourceStreamImpl.cpp?view=diff&rev=648&p1=trunk/MgDev/Common/Service/Data/ByteSourceStreamImpl.cpp&r1=647&p2=trunk/MgDev/Common/Service/Data/ByteSourceStreamImpl.cpp&r2=648
File: trunk/MgDev/Common/Service/Data/ByteSourceStreamImpl.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Data/ByteSourceStreamImpl.h?view=diff&rev=648&p1=trunk/MgDev/Common/Service/Data/ByteSourceStreamImpl.h&r1=647&p2=trunk/MgDev/Common/Service/Data/ByteSourceStreamImpl.h&r2=648
File: trunk/MgDev/Common/Service/Exception/ThirdPartyException.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Exception/ThirdPartyException.cpp?view=diff&rev=648&p1=trunk/MgDev/Common/Service/Exception/ThirdPartyException.cpp&r1=647&p2=trunk/MgDev/Common/Service/Exception/ThirdPartyException.cpp&r2=648
File: trunk/MgDev/Common/Service/Exception/ThirdPartyException.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Exception/ThirdPartyException.h?view=diff&rev=648&p1=trunk/MgDev/Common/Service/Exception/ThirdPartyException.h&r1=647&p2=trunk/MgDev/Common/Service/Exception/ThirdPartyException.h&r2=648
File: trunk/MgDev/Server/src/Resources/server_en.res https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Resources/server_en.res?view=diff&rev=648&p1=trunk/MgDev/Server/src/Resources/server_en.res&r1=647&p2=trunk/MgDev/Server/src/Resources/server_en.res&r2=648
File: trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.cpp?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.cpp&r1=647&p2=trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.cpp&r2=648
File: trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.h?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.h&r1=647&p2=trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.h&r2=648
File: trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp&r1=647&p2=trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp&r2=648
File: trunk/MgDev/Server/src/Services/Resource/ByteSourceDwfInputStreamImpl.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ByteSourceDwfInputStreamImpl.cpp?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Resource/ByteSourceDwfInputStreamImpl.cpp&r1=647&p2=trunk/MgDev/Server/src/Services/Resource/ByteSourceDwfInputStreamImpl.cpp&r2=648
File: trunk/MgDev/Server/src/Services/Resource/ByteSourceDwfInputStreamImpl.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ByteSourceDwfInputStreamImpl.h?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Resource/ByteSourceDwfInputStreamImpl.h&r1=647&p2=trunk/MgDev/Server/src/Services/Resource/ByteSourceDwfInputStreamImpl.h&r2=648
File: trunk/MgDev/Server/src/Services/Resource/RepositoryManager.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/RepositoryManager.cpp?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Resource/RepositoryManager.cpp&r1=647&p2=trunk/MgDev/Server/src/Services/Resource/RepositoryManager.cpp&r2=648
File: trunk/MgDev/Server/src/Services/Resource/RepositoryManager.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/RepositoryManager.h?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Resource/RepositoryManager.h&r1=647&p2=trunk/MgDev/Server/src/Services/Resource/RepositoryManager.h&r2=648
File: trunk/MgDev/Server/src/Services/Resource/ResourceDataFileManager.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceDataFileManager.cpp?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Resource/ResourceDataFileManager.cpp&r1=647&p2=trunk/MgDev/Server/src/Services/Resource/ResourceDataFileManager.cpp&r2=648
File: trunk/MgDev/Server/src/Services/Resource/ResourceDataStreamManager.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceDataStreamManager.cpp?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Resource/ResourceDataStreamManager.cpp&r1=647&p2=trunk/MgDev/Server/src/Services/Resource/ResourceDataStreamManager.cpp&r2=648
File: trunk/MgDev/Server/src/Services/Resource/ResourceDefinitionManager.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceDefinitionManager.cpp?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Resource/ResourceDefinitionManager.cpp&r1=647&p2=trunk/MgDev/Server/src/Services/Resource/ResourceDefinitionManager.cpp&r2=648
File: trunk/MgDev/Server/src/Services/Resource/ResourceManager.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceManager.h?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Resource/ResourceManager.h&r1=647&p2=trunk/MgDev/Server/src/Services/Resource/ResourceManager.h&r2=648
File: trunk/MgDev/Server/src/Services/Resource/ResourceServiceDefs.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceServiceDefs.h?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Resource/ResourceServiceDefs.h&r1=647&p2=trunk/MgDev/Server/src/Services/Resource/ResourceServiceDefs.h&r2=648
File: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp&r1=647&p2=trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp&r2=648
File: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h?view=diff&rev=648&p1=trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h&r1=647&p2=trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h&r2=648
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
