[mapguide][MG252][Modified] Server hung/crashed after running load tests
Steve Dang
steve.dang at autodesk.com
Sun May 14 00:01:04 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG252
Type:
Defect
Artifact ID:
MG252 (Server hung/crashed after running load tests)
Modified by:
Steve Dang
stevedang (steve.dang at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
Removed the MgOperationThread::CheckStream method.
Windows Server unit tests failed/run: 0/380
Windows Web Tier unit tests failed/run: 0/934
Linux Server unit tests failed/run: 0/380
Modified
File: trunk/MgDev/Server/src/Core/OperationThread.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Core/OperationThread.cpp?view=diff&rev=649&p1=trunk/MgDev/Server/src/Core/OperationThread.cpp&r1=648&p2=trunk/MgDev/Server/src/Core/OperationThread.cpp&r2=649
File: trunk/MgDev/Server/src/Core/OperationThread.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Core/OperationThread.h?view=diff&rev=649&p1=trunk/MgDev/Server/src/Core/OperationThread.h&r1=648&p2=trunk/MgDev/Server/src/Core/OperationThread.h&r2=649
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
