[mapguide][MG289][Modified] Joins do not work when join property types are different
Ronnie Louie ronnie.louie at autodesk.com
Sun May 14 12:47:06 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG289
Type:
Defect
Artifact ID:
MG289 (Joins do not work when join property types are different)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- Testing Notes set to new value:
Server unit tests 380/380 tests OK
-- Resolution Description set to new value:
Added logic in the GwsQueryEngine to allow string-numeric and numeric-string comparison.  Comparison operator will be LIKE for these types and will also do a check for wildcards so that a wildcard LIKE query is not done inadvertently.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
