[mapguide][MG290][Modified] GetDrawingLayer returns an empty DWF in some cases
Ronnie Louie
ronnie.louie at autodesk.com
Sun May 14 13:01:02 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG290
Type:
Defect
Artifact ID:
MG290 (GetDrawingLayer returns an empty DWF in some cases)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- External ID set to new value:
696788
-- Resolution Description set to new value:
An error occurs when processing the WT_Polymarker objects (point geometry) in this DWF which causes the processing loop to exit. Because of the premature exit, the polylines do not get processed.
The early exit from the processing loop is due to WT_Polymarker being a deprecated, and when serialize is called, it returns a Toolkit_Usage_Error code. The fix is to use the new WT_Macro_Draw object to serialize the point geometry. WT_Macro_Draw is a new WT_Drawable object that is supposed to replace WT_Polymarker.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
