[mapguide][MG291][User] layerdefinition.php uses localhost to try to load files. Th...
Alain Lebatard alain.lebatard at autodesk.com
Mon May 15 18:29:21 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG291
Type:
Defect
Artifact ID:
MG291 (layerdefinition.php uses localhost to try to load files.  This does not work for all situations.)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- New value added to attribute Assigned to:
alainlebatard
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
