[mapguide][MG291][Modified] layerdefinition.php uses localhost to try to load files. Th...
Alain Lebatard
alain.lebatard at autodesk.com
Mon May 15 20:08:10 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG291
Type:
Defect
Artifact ID:
MG291 (layerdefinition.php uses localhost to try to load files. This does not work for all situations.)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution Description set to new value:
Fix submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
