[mapguide][MG188][Modified] Script error when changing scale before map is loaded in AJA...
Trevor Wekel trevor.wekel at autodesk.com
Thu May 18 12:45:21 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG188
Type:
Defect
Artifact ID:
MG188 (Script error when changing scale before map is loaded in AJAX viewer)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Review Comments set to new value:
Looks ok.
-- Submission Reviewed set to new value:
Yes
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
