[mapguide][MG292][New] Incorrect quotes escaping in viewer's mainframe in JSP
Alain Lebatard
alain.lebatard at autodesk.com
Thu May 18 16:57:59 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG292
Type
Defect
Artifact ID
MG292 (Incorrect quotes escaping in viewer's mainframe in JSP)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Priority set to new value
P1
- Steps to Reproduce set to new value
Create a web layout containing a search command with an expression filter including a property name.
Load the web layout in a web browser
-> script erors. the viewer wont't load successfully
- Summary set to new value
- Subcomponent set to new value
Viewer Command
- Version set to new value
1.0.0
- Defect Severity set to new value
Critical
- Description set to new value
The strings containing quotes are not correctly escaped in the code producing the main frame in JSP.
The problem is revealed with recent version of Studio which now surrounds property names with double-quotes. When a web layout defines a search command with a property name in the filter expression, the viewer fails to load.
ASP.NET and PHP implementations are not affected by the problem.
- Component set to new value
Web Server Extensions
- Artifact Status set to new value
New
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
