[mapguide][MG292][Modified] Incorrect quotes escaping in viewer's mainframe in JSP
Alain Lebatard alain.lebatard at autodesk.com
Thu May 18 17:03:17 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG292
Type:
Defect
Artifact ID:
MG292 (Incorrect quotes escaping in viewer's mainframe in JSP)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
-- Resolution Description set to new value:
Fix submitted.
Don't be scared by the number of backslashes in the fixed code. This is due to the reg. expression language used by  Java's String.replaceAll method
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
