[mapguide][MG296][New] Define Search Command using Like $USER_VARIABLE doesn't work
Alain Lebatard alain.lebatard at autodesk.com
Fri May 19 16:42:18 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG296
Type
 Defect
Artifact ID
 MG296 (Define Search Command using Like $USER_VARIABLE doesn't work)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Defect Severity set to new value
  High
- Description set to new value
  If a user adds a custom search menu option to their weblayout the default syntax when it's built does not wrap single quotes around $USER_VARIABLE.
Regardless of which operator the author is using for comparison without the quotes the $USER_VARIABLE will not be interpreted as a variable and hence the search will fail everytime without any error to the map user.
- Artifact Status set to new value
  New
- Component set to new value
  Web Server Extensions
- Priority set to new value
  P2
- Subcomponent set to new value
  Viewer Command
- Summary set to new value
- Artifact created
- Platform set to new value
  All
- Steps to Reproduce set to new value
  Create a web layout containing a search command with an expression filter including a property name.
Load the web layout in a web browser and execute the search command
  -> All features on the specified layer are mateched by search. Only features satisfying the expression filter should match.
- Version set to new value
  1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
