[mapguide][MG210][Modified] Fix more server leaks
Walt Welton-Lair walt.welton-lair at autodesk.com
Sat May 20 00:52:39 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG210
Type:
Defect
Artifact ID:
MG210 (Fix more server leaks)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Resolution Description set to new value:
Code fixes have been submitted.
-- Status Explanation set to new value:
-- Submission Reviewed set to new value:
No
-- Testing Notes set to new value:
Old value:
Ran web-tier tests on open source server (934/934 passed).
New value:
FDO leaks have been fixed.
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
