[mapguide][MG267][Modified] Update description for port number used for Admin/client/sit...
Hartesh Chhabra
hartesh.chhabra at autodesk.com
Sat May 20 22:08:18 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG267
Type:
Defect
Artifact ID:
MG267 (Update description for port number used for Admin/client/site operations in serverconfig.ini and webconfig.ini files)
Modified by:
Hartesh Chhabra
harteshchhabra (hartesh.chhabra at autodesk.com)
The following modifications were made to this artifact:
-- Review Comments set to new value:
Looks good.
-- Submission Reviewed set to new value:
Yes
-- Description set to new value:
Old value:
If port number used for Administrative or Cleint or Site opertaions is updated in serverconfig.ini file, the corresponding port number need to be updated in webconfig.ini file as well and vice versa
New value:
If port number used for Administrative or Cleint or Site opertaions is updated in serverconfig.ini file, the corresponding port number need to be updated in webconfig.ini file as well and vice versa.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
