[mapguide][MG299][New] Update logging to include USER parameter infomation for conn...
Bruce Dechant bruce.dechant at autodesk.com
Thu May 25 16:22:17 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG299
Type
 Defect
Artifact ID
 MG299 (Update logging to include USER parameter infomation for connections using a session ID)
Reported by
 Bruce Dechant
 brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Platform set to new value
  All
- Component set to new value
  Server
- Priority set to new value
  P3
- Defect Severity set to new value
  Low
- Summary set to new value
- Artifact Status set to new value
  New
- Version set to new value
  1.0.0
- Operating system set to new value
  All
- Artifact created
- Description set to new value
  Operations that involve a session ID are not writting out the USER parameter to the log file.
- Subcomponent set to new value
  Core
- Steps to Reproduce set to new value
  Enable the Access log with the USER parameter set. Then perform any operation using a session ID. Open the Access log and you will notice that the USER parameter information is not there.
- Target milestone set to new value
  1.0.1
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
