[mapguide][MG300][New] String inlining creates toolbar script error
Alain Lebatard
alain.lebatard at autodesk.com
Thu May 25 18:33:30 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG300
Type
Defect
Artifact ID
MG300 (String inlining creates toolbar script error)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Version set to new value
1.0.0
- Artifact Status set to new value
New
- Subcomponent set to new value
Viewer Command
- Component set to new value
Web Server Extensions
- Steps to Reproduce set to new value
In the web layout, create a new built-in command "zoom in" and set the description to:
Test with single ' and double " quotes
Replace the predefined zoom in command with the new command in the toolbar.
Open the web layout
Move the mouse over the zoom in button
=> script error
- Artifact created
- Defect Severity set to new value
High
- Description set to new value
The toolbar script fails when the command description of a toolbar button contain quotes.
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
