[mapguide][MG302][Modified] Sheboygan DWF Viewer sample unstable under load
Trevor Wekel
trevor.wekel at autodesk.com
Wed May 31 18:07:50 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG302
Type:
Defect
Artifact ID:
MG302 (Sheboygan DWF Viewer sample unstable under load)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Resolution Description set to new value:
Code change submitted.
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Status Explanation set to new value:
Old value:
Work in progress.
New value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
