[mapguide][MG303][New] GLOB: Viewer with LOCALE=ja causes script error in IE.
Alain Lebatard alain.lebatard at autodesk.com
Wed May 31 19:10:17 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG303
Type
 Defect
Artifact ID
 MG303 (GLOB: Viewer with LOCALE=ja causes script error in IE.)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Summary set to new value
- Component set to new value
  Web Server Extensions
- Operating system set to new value
  Linux
- Description set to new value
  Server= Linux
1. From Windows client machine, create a new web layout with Sheboygam map in it, then save it.
2. Open newly created web layout with AJAX or DWF viewer.
3. Verify no script error appears at lower lefet corner of IE and objects appear in drawing area.
4. Add locale information for JPN as LOCALE=ja at the end of URL.
Problem.
1. No object displays.
2. Script error
- Version set to new value
  1.0.0
- Subcomponent set to new value
  General
- Artifact Status set to new value
  New
- Defect Severity set to new value
  Critical
- Priority set to new value
  P1
- Artifact created
- Steps to Reproduce set to new value
Problem.
2. Script error
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
