[mapguide][MG443][Modified] Typecasting of MgCoordinate to derived classes fails
Trevor Wekel trevor.wekel at autodesk.com
Wed Nov 1 12:30:16 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG443
Type:
Defect
Artifact ID:
MG443 (Typecasting of MgCoordinate to derived classes fails)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
MgCoordinate cannot be cast to MgCoordinateXY, XYZ, XYM, and XYZM.  .Net autogenerated properties are not visible for MgCoordinate and a variety of other classes.
New value:
MgByteReader::ToString() only allows conversion once.
-- Resolution Description set to new value:
Old value:
MgCoordinate derived classes were misssing CLASS_ID in their headers so IMake/Swig could not generate the appropriate casting logic.
A bug in IMake prevented property autogeneration when additional tokens appeared between the method name and the __get/__set comment eg:
GetX() = 0;  /// __get
The extra two tokens caused the generation logic to fail.
New value:
MgByteReader::ToString() only allows the reader to be converted to a string once.  Since most byte readers can be rewound, this is an unnecessary limitation.  An automatic rewind has been added to the method.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
