[mapguide][MG444][New] Web Layout Search does not work with Joined fields
Andrew Morsell amorsell at spatialgis.com
Thu Nov 2 17:06:27 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG444
Type
 Defect
Artifact ID
 MG444 (Web Layout Search does not work with Joined fields)
Reported by
 Andrew Morsell
 amorsell (amorsell at spatialgis.com)
New artifact details:
- Summary set to new value
- Platform set to new value
  All
- Defect Severity set to new value
  High
- Version set to new value
  1.0.2
- Artifact created
- Artifact Status set to new value
  New
- Steps to Reproduce set to new value
  Define a web layout Search from a data extender joined field and then attempt to use it.
- Subcomponent set to new value
  Feature Service
- Description set to new value
  In Studio, when defining a Search in a web layout, it allows you to choose a data extender joined field on which to base the search.  But, when executing that search from with the web layout, the following errors occur.
>From MGOS: "An exception occurred in FDO component. Invalid identifier name '<Field Name>'. Exception occurred in method MgServerGwsGetFeatures.GetMgClassDefinition at line 207 in file c:\build_tux_area\mgdev\server\src\services\feature\ServerGwsGetFeatures.cpp"
>From MGE "An exception occurred in FDO component. Invalid identifier name 'FLATATS_TDATA1'.
- MgServerGwsFeatureReader.Serialize line 603 file c:\build_tux_area\mgdev\server\src\services\feature\ServerGwsFeatureReader.cpp - MgServerGwsGetFeatures.GetFeatures line 93 file c:\build_tux_area\mgdev\server\src\services\feature\ServerGwsGetFeatures.cpp - MgServerGwsGetFeatures.GetMgClassDefinition line 207 file c:\build_tux_area\mgdev\server\src\services\feature\ServerGwsGetFeatures.cpp"
- Operating system set to new value
  All
- Component set to new value
  Web Server Extensions
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
