[mapguide][MG455][New] DWFRenderer leaks memory after encountering stylization exce...
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Nov 23 12:22:20 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG455
Type
Defect
Artifact ID
MG455 (DWFRenderer leaks memory after encountering stylization exception)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Priority set to new value
P2
- Steps to Reproduce set to new value
Raise an exception after a call to DWFRenderer::StartLayer and before DWFRenderer::EndLayer. If the layer has attributes associated with it, then the m_attributes pointer will not be freed.
- Summary set to new value
- Artifact created
- Defect Severity set to new value
Medium
- Description set to new value
If an exception is raised while rendering DWF output during StylizeFeatures, then the DWFRenderer can leak memory. In particular, the m_attributes pointer is not freed. This references a DWFObjectDefinitionResource object.
- Version set to new value
1.0.2
- Target milestone set to new value
1.1.0
- Artifact Status set to new value
New
- Operating system set to new value
All
- Platform set to new value
All
- Subcomponent set to new value
Core
- Component set to new value
Server
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
