[mapguide][MG459][New] Fix for 860954
Reva Revadigar
reva.revadigar at autodesk.com
Wed Nov 29 14:03:50 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG459
Type
Defect
Artifact ID
MG459 (Fix for 860954)
Reported by
Reva Revadigar
revadir (reva.revadigar at autodesk.com)
New artifact details:
- Version set to new value
1.0.2
- Submission Reviewed set to new value
Yes
- Summary set to new value
Fix for 860954
- Operating system set to new value
All
- Artifact created
- Component set to new value
Server
- Priority set to new value
P3
- Platform set to new value
All
- Steps to Reproduce set to new value
1. Launch Map
2. Load a layer by drag/drop of a .layer file pointing to a polygon layer.
3. Edit style of layer by adding a theme with default properties.
Result:
Boundschecker reports 33 leaks of 32 bytes each (sizeof a MdfString) at source location:
LengthConverter::UnitToEnglish - [lengthconverter.cpp, line 138 (MgMdfModeld.dll)]
The function LengthConverter::UnitToEnglish() is allocating memory for an MdfString and returning a pointer to the newly created string. Callers must free this string. Right now they are not doing this.
- Defect Severity set to new value
Low
- Artifact Status set to new value
New
- Resolution set to new value
Submitted
- Target milestone set to new value
1.1.0
- Subcomponent set to new value
Core
- Description set to new value
I'm fixing memory leaks in Map and I came across some memory leaks in the GisPlatform code, which is shared between Map and MapGuide. What I found was that callers to LengthConverter::UnitToEnglish() need to free the returned string. That method is in MdfModel.dll, but it is being called from two places in MdfParser.dll. So I need to modify IOStroke.cpp and IOSymbol.cpp. I need to make the following changes:
IoStroke.cpp:
98c98,99
< fd << EncodeString(*LengthConverter::UnitToEnglish(stroke->GetUnit()));
> std::auto_ptr<MdfString> str(LengthConverter::UnitToEnglish(stroke->GetUnit()));
> fd << EncodeString(*str);
IoSymbol.cpp:
< fd << EncodeString(*LengthConverter::UnitToEnglish(m_symbol->GetUnit()));
> std::auto_ptr<MdfString> str(LengthConverter::UnitToEnglish(m_symbol->GetUnit()));
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
