[mapguide][MG410][New] URL Activated for Feature Problem
Bill Powell
bpowell at fortsask.ca
Tue Oct 3 00:16:44 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG410
Type
Defect
Artifact ID
MG410 (URL Activated for Feature Problem)
Reported by
Bill Powell
bpowell (bpowell at fortsask.ca)
New artifact details:
- Artifact created
- Defect Severity set to new value
Medium
- Steps to Reproduce set to new value
1. Add a layer to any project that contains a data field with a url structured as shown above.
2. Add this layer to a map, then to a web layout.
3. While viewing the weblayout hover over the layer in question and make note of the url displayed. Try this in both viewers to see the extra padding added for the DWF viewer
4. Ctl + Click the hyperlink in both viewers to view the results.
- Operating system set to new value
Windows XP
- Component set to new value
Viewer
- Summary set to new value
- Version set to new value
1.0.1
- Artifact Status set to new value
New
- Subcomponent set to new value
DWF Viewer
- Platform set to new value
PC
- Description set to new value
URL Activated for Feature has strange behaviour for DWF viewer, but works as expected for AJAX viewer. In a sample dataset I have enabled the URL for one of the property fields. The field happens to be structured as follows:
http://MySite.ca/GetFeatureAttributes.xml?FeatureId=10105
In AJAX viewer this works fine however in the DWF viewer, the characters following the = operator are padded with single quotes which makes the navigation fail:
http://MySite.ca/GetFeatureAttributes.xml?FeatureId='10105'
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
