[mapguide][MG403][Modified] Add tags for SWIG generation of automatic .NET properties fo...
Trevor Wekel trevor.wekel at autodesk.com
Tue Oct 3 14:26:54 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG403
Type:
Enhancement
Artifact ID:
MG403 (Add tags for SWIG generation of automatic .NET properties for Platform API)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Review Comments set to new value:
Looks good.  A lot of work...  Does IMake still work on Linux?  Not a major issue.  The submitted IMake code should have no impact on Java or PHP.
-- Submission Reviewed changed:
Old value:
No
New value:
Yes
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
