[mapguide][MG413][New] [WebStudio] MapDefinition CoordinateSystem not saved and int...
Zak James zjames at dmsolutions.ca
Tue Oct 3 21:20:26 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG413
Type
 Defect
Artifact ID
 MG413 ([WebStudio] MapDefinition CoordinateSystem not saved and intially invalid)
Reported by
 Zak James
 zjames (zjames at dmsolutions.ca)
New artifact details:
- Artifact Status set to new value
  New
- Defect Severity set to new value
  Medium
- Component set to new value
  Web Server Extensions
- Summary set to new value
- Artifact created
- Description set to new value
  The WebStudio map settings editor does not correctly set the xml for coordinate system so changes are not persisted. Also, the initial xml template used for MapDefinitions is not valid because the coordinate system tag has no content.
- Steps to Reproduce set to new value
  1. Create a new MapDefinition or open an existing one.
2. Add or modify coordinate system entry in the settings editor
3. Save the resource
4. Reopen the resource.
result:
No change is made
correct result:
Resource should display the modified entry.
- Version set to new value
  1.0.1
- Platform set to new value
  All
- Subcomponent set to new value
  Web Studio
- Operating system set to new value
  All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
