[mapguide][MG411][Modified] Allow negative buffer offsets
Walt Welton-Lair walt.welton-lair at autodesk.com
Wed Oct 4 06:05:03 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG411
Type:
Enhancement
Artifact ID:
MG411 (Allow negative buffer offsets)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG411
Added
File: trunk/MgDev/Common/Geometry/Buffer/plgnsbak.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/plgnsbak.cpp?view=auto&rev=846
File: trunk/MgDev/Common/Geometry/Buffer/plgnsbak.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/plgnsbak.h?view=auto&rev=846
Modified
File: trunk/MgDev/Common/Geometry/Buffer/GreatCircleBufferUtil.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/GreatCircleBufferUtil.cpp?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/Buffer/GreatCircleBufferUtil.cpp&r1=845&p2=trunk/MgDev/Common/Geometry/Buffer/GreatCircleBufferUtil.cpp&r2=846
File: trunk/MgDev/Common/Geometry/Buffer/GreatCircleBufferUtil.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/GreatCircleBufferUtil.h?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/Buffer/GreatCircleBufferUtil.h&r1=845&p2=trunk/MgDev/Common/Geometry/Buffer/GreatCircleBufferUtil.h&r2=846
File: trunk/MgDev/Common/Geometry/Buffer/LatLonBorderWalker.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/LatLonBorderWalker.cpp?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/Buffer/LatLonBorderWalker.cpp&r1=845&p2=trunk/MgDev/Common/Geometry/Buffer/LatLonBorderWalker.cpp&r2=846
File: trunk/MgDev/Common/Geometry/Buffer/MgBuffer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/MgBuffer.cpp?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/Buffer/MgBuffer.cpp&r1=845&p2=trunk/MgDev/Common/Geometry/Buffer/MgBuffer.cpp&r2=846
File: trunk/MgDev/Common/Geometry/Buffer/buffer.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/buffer.h?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/Buffer/buffer.h&r1=845&p2=trunk/MgDev/Common/Geometry/Buffer/buffer.h&r2=846
File: trunk/MgDev/Common/Geometry/Buffer/bufrutil.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/bufrutil.cpp?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/Buffer/bufrutil.cpp&r1=845&p2=trunk/MgDev/Common/Geometry/Buffer/bufrutil.cpp&r2=846
File: trunk/MgDev/Common/Geometry/Buffer/orpplygn.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/orpplygn.cpp?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/Buffer/orpplygn.cpp&r1=845&p2=trunk/MgDev/Common/Geometry/Buffer/orpplygn.cpp&r2=846
File: trunk/MgDev/Common/Geometry/Buffer/orpplygn.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/orpplygn.h?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/Buffer/orpplygn.h&r1=845&p2=trunk/MgDev/Common/Geometry/Buffer/orpplygn.h&r2=846
File: trunk/MgDev/Common/Geometry/Buffer/plgnbufr.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/plgnbufr.cpp?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/Buffer/plgnbufr.cpp&r1=845&p2=trunk/MgDev/Common/Geometry/Buffer/plgnbufr.cpp&r2=846
File: trunk/MgDev/Common/Geometry/Buffer/pobjbufr.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/pobjbufr.h?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/Buffer/pobjbufr.h&r1=845&p2=trunk/MgDev/Common/Geometry/Buffer/pobjbufr.h&r2=846
File: trunk/MgDev/Common/Geometry/Geometry.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Geometry.cpp?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/Geometry.cpp&r1=845&p2=trunk/MgDev/Common/Geometry/Geometry.cpp&r2=846
File: trunk/MgDev/Common/Geometry/Geometry.vcproj https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Geometry.vcproj?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/Geometry.vcproj&r1=845&p2=trunk/MgDev/Common/Geometry/Geometry.vcproj&r2=846
File: trunk/MgDev/Common/Geometry/GeometryBuild.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/GeometryBuild.cpp?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/GeometryBuild.cpp&r1=845&p2=trunk/MgDev/Common/Geometry/GeometryBuild.cpp&r2=846
File: trunk/MgDev/Common/Geometry/Makefile.am https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Makefile.am?view=diff&rev=846&p1=trunk/MgDev/Common/Geometry/Makefile.am&r1=845&p2=trunk/MgDev/Common/Geometry/Makefile.am&r2=846
File: trunk/MgDev/Server/src/Resources/server_en.res https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Resources/server_en.res?view=diff&rev=846&p1=trunk/MgDev/Server/src/Resources/server_en.res&r1=845&p2=trunk/MgDev/Server/src/Resources/server_en.res&r2=846
File: trunk/MgDev/Web/src/mapagent/Resources/web_en.res https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapagent/Resources/web_en.res?view=diff&rev=846&p1=trunk/MgDev/Web/src/mapagent/Resources/web_en.res&r1=845&p2=trunk/MgDev/Web/src/mapagent/Resources/web_en.res&r2=846
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
