[mapguide][MG411][Modified] Allow negative buffer offsets
Walt Welton-Lair
walt.welton-lair at autodesk.com
Wed Oct 4 06:42:49 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG411
Type:
Enhancement
Artifact ID:
MG411 (Allow negative buffer offsets)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Developer Notes set to new value:
* Updated the public API to allow negative buffer offsets. Note that negative offsets only make sense for polygons.
* Implementation of this for polygons is actually straightforward. In the normal case (positive offset) we create the buffer using PolygonBuffer::CreateBufferZone. This generates a buffer on either side of the polygon boundary, and the inner buffer is eventually discarded. For the negative offset case, we use a new class called PolygonSetback which inherits from PolygonBuffer. Both sides of the polygon are again buffered, but we override the AcceptBoundary method so that now the outer buffer gets discarded.
* The m_hookEdgeLength variable was not getting properly initialized in BufferUtility. Fixed this.
* Added a ReverseBoundaries method to OrientedPolyPolygon. The polygons created by the setback code have the reverse orientation (CW), and they need to be changed back to CCW before creating an OrientedPolyPolygonUnion.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
