[mapguide][MG414][New] AJAX and DWF viewer - map size in status bar does not update
Chris Claydon chris.claydon at autodesk.com
Wed Oct 4 11:21:33 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG414
Type
 Defect
Artifact ID
 MG414 (AJAX and DWF viewer - map size in status bar does not update)
Reported by
 Chris Claydon
 chrisclaydon (chris.claydon at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Defect Severity set to new value
  Low
- Steps to Reproduce set to new value
  Zoom in or out on the map. Map size does not change.
- Priority set to new value
  P4
- Version set to new value
  1.0.1
- Description set to new value
  When zooming in or out on a map using the AJAX or DWF viewer, the map size displayed in the status bar (if enabled) does not update.
- Artifact created
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
