[mapguide][MG414][Modified] AJAX and DWF viewer - map size in status bar does not update
Chris Claydon chris.claydon at autodesk.com
Wed Oct 4 11:56:55 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG414
Type:
Defect
Artifact ID:
MG414 (AJAX and DWF viewer - map size in status bar does not update)
Modified by:
Chris Claydon
chrisclaydon (chris.claydon at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Target milestone set to new value:
1.1.0
-- Resolution set to new value:
Submitted
-- Status Explanation set to new value:
Code fix.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
