[mapguide][MG413][Modified] [WebStudio] MapDefinition CoordinateSystem not saved and int...
Zak James zjames at dmsolutions.ca
Wed Oct 4 16:07:08 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG413
Type:
Defect
Artifact ID:
MG413 ([WebStudio] MapDefinition CoordinateSystem not saved and intially invalid)
Modified by:
Zak James
zjames (zjames at dmsolutions.ca)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Resolution Description set to new value:
Added code to detect the proper id within the map settings panel.
Added 'none' as default coordinate system in the map template
-- Status Explanation set to new value:
The coordinate system setting problem is resolved, but the added value in the template's CoordinateSystem Tag causes a server exception to appear in the preview window since 'None' is an invalid coordinate system WKT string.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
