[mapguide][MG416][Modified] Fix some minor memory leaks
Walt Welton-Lair walt.welton-lair at autodesk.com
Thu Oct 5 04:37:51 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG416
Type:
Defect
Artifact ID:
MG416 (Fix some minor memory leaks)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG416
Modified
File: trunk/MgDev/Common/PlatformBase/Data/BlobProperty.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/PlatformBase/Data/BlobProperty.cpp?view=diff&rev=858&p1=trunk/MgDev/Common/PlatformBase/Data/BlobProperty.cpp&r1=857&p2=trunk/MgDev/Common/PlatformBase/Data/BlobProperty.cpp&r2=858
File: trunk/MgDev/Common/PlatformBase/Data/ClobProperty.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/PlatformBase/Data/ClobProperty.cpp?view=diff&rev=858&p1=trunk/MgDev/Common/PlatformBase/Data/ClobProperty.cpp&r1=857&p2=trunk/MgDev/Common/PlatformBase/Data/ClobProperty.cpp&r2=858
File: trunk/MgDev/Common/PlatformBase/Services/RasterProperty.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/PlatformBase/Services/RasterProperty.cpp?view=diff&rev=858&p1=trunk/MgDev/Common/PlatformBase/Services/RasterProperty.cpp&r1=857&p2=trunk/MgDev/Common/PlatformBase/Services/RasterProperty.cpp&r2=858
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
