[mapguide][MG418][New] Buffering using large setbacks generates exceptions
Walt Welton-Lair walt.welton-lair at autodesk.com
Thu Oct 5 11:57:37 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG418
Type
 Defect
Artifact ID
 MG418 (Buffering using large setbacks generates exceptions)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Artifact created
- Artifact Status set to new value
  New
- Subcomponent set to new value
  Core
- Summary set to new value
- Target milestone set to new value
  1.1.0
- Defect Severity set to new value
  Critical
- Priority set to new value
  P1
- Component set to new value
  Server
- Steps to Reproduce set to new value
  Select a polygon and buffer it using a setback (negative offset) which is large than the polygon.  MapGuide will generate an exception.
- Platform set to new value
  All
- Version set to new value
  1.0.1
- Description set to new value
  See summary...
- Operating system set to new value
  All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
