[mapguide][MG418][Modified] Buffering using large setbacks generates exceptions
Walt Welton-Lair walt.welton-lair at autodesk.com
Thu Oct 5 11:58:54 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG418
Type:
Defect
Artifact ID:
MG418 (Buffering using large setbacks generates exceptions)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG418
Modified
File: trunk/MgDev/Common/Geometry/Buffer/MgBuffer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/MgBuffer.cpp?view=diff&rev=868&p1=trunk/MgDev/Common/Geometry/Buffer/MgBuffer.cpp&r1=867&p2=trunk/MgDev/Common/Geometry/Buffer/MgBuffer.cpp&r2=868
File: trunk/MgDev/Common/Geometry/Buffer/planeswp.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/planeswp.cpp?view=diff&rev=868&p1=trunk/MgDev/Common/Geometry/Buffer/planeswp.cpp&r1=867&p2=trunk/MgDev/Common/Geometry/Buffer/planeswp.cpp&r2=868
File: trunk/MgDev/Common/Geometry/Buffer/plgnsbak.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Buffer/plgnsbak.cpp?view=diff&rev=868&p1=trunk/MgDev/Common/Geometry/Buffer/plgnsbak.cpp&r1=867&p2=trunk/MgDev/Common/Geometry/Buffer/plgnsbak.cpp&r2=868
File: trunk/MgDev/Common/Geometry/Geometry.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Geometry/Geometry.h?view=diff&rev=868&p1=trunk/MgDev/Common/Geometry/Geometry.h&r1=867&p2=trunk/MgDev/Common/Geometry/Geometry.h&r2=868
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
