[mapguide][MG359][Modified] Long running requests cause Linux Server to exit after MapAg...
Steve Dang
steve.dang at autodesk.com
Thu Oct 5 16:26:37 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG359
Type:
Defect
Artifact ID:
MG359 (Long running requests cause Linux Server to exit after MapAgent bails)
Modified by:
Steve Dang
stevedang (steve.dang at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
Modified
File: trunk/MgDev/Common/Foundation/Data/ByteSink.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/Data/ByteSink.cpp?view=diff&rev=870&p1=trunk/MgDev/Common/Foundation/Data/ByteSink.cpp&r1=869&p2=trunk/MgDev/Common/Foundation/Data/ByteSink.cpp&r2=870
File: trunk/MgDev/Common/Foundation/Foundation.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/Foundation.h?view=diff&rev=870&p1=trunk/MgDev/Common/Foundation/Foundation.h&r1=869&p2=trunk/MgDev/Common/Foundation/Foundation.h&r2=870
File: trunk/MgDev/Common/Foundation/System/AceStreamHelper.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/System/AceStreamHelper.cpp?view=diff&rev=870&p1=trunk/MgDev/Common/Foundation/System/AceStreamHelper.cpp&r1=869&p2=trunk/MgDev/Common/Foundation/System/AceStreamHelper.cpp&r2=870
File: trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionImp.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionImp.cpp?view=diff&rev=870&p1=trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionImp.cpp&r1=869&p2=trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionImp.cpp&r2=870
File: trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp?view=diff&rev=870&p1=trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp&r1=869&p2=trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp&r2=870
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
