[mapguide][MG419][Modified] Calling MgRing->GetArea generates assertion
Walt Welton-Lair walt.welton-lair at autodesk.com
Mon Oct 9 08:45:33 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG419
Type:
Defect
Artifact ID:
MG419 (Calling MgRing->GetArea generates assertion)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
GetArea is published API, and it doesn't work correctly for linear and curve rings.
New value:
GetArea is published API, but it doesn't work for linear rings and curve rings.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
