[mapguide][MG420][New] Global installer workaround: Add hardcoded string to branch ...
Bruce Dechant
bruce.dechant at autodesk.com
Tue Oct 10 12:53:06 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG420
Type
Defect
Artifact ID
MG420 (Global installer workaround: Add hardcoded string to branch only)
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Description set to new value
The following string resource entry will be hardcoded for the release of service pack 1 only:
MgStylizeLayerFailedException
The reason for this is to allow the global installer to be used without requiring the resources to be updated inside the global installer.
This only effects the service pack 1 branch of the code and not the trunk. The trunk will use the string resource entry because the global installer will be updated in the future.
- Priority set to new value
P3
- Defect Severity set to new value
Low
- Summary set to new value
- Artifact created
- Version set to new value
1.0.1
- Steps to Reproduce set to new value
N/A
- Target milestone set to new value
1.0.2
- Artifact Status set to new value
New
- Operating system set to new value
All
- Component set to new value
Server
- Platform set to new value
All
- Subcomponent set to new value
Mapping Service
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
